Ok so you can read my sig and see what I've done to the ole girl. I has some pump questions. My FSS quit after turning the pump up. I have removed it looked at it put it back on. I'm moving too much fuel for it to work. I put the m and h spacer on. There is another solenoid looking thing there with a wire attached. So here's the question. When I remove the wire from the FSS and the gadget where I installed the spacer the truck runs much smoother at idle
why?????
why?????
