Smokinblues, I definitely agree with your recommendation to upgrade the transmission first because the stock tranny is barely up for the stock power level, which isn't much.
So the bare minimum (if tranny is already in pretty good shape, no burnt clutches etc...) would be to buy/install an HD Torque Convertor & HD Valve Body. The heavier-duty tranny components will be necessary to not only put the power to the ground, but prevent trans-destruction under power mods.
Don't waste your $$$ on fuel plates from ANYONE!!
Seriously, I'm not joking take your factory fuel plate out. Cut it flat (w/ a Dremel or grinder) to remove defueling features. Put it back in the pump and slide it forward.
Then slide the AFC housing forward (like it says in this link):
Diesel Database :: Turning Up A P7100 Pump
Like smokinblues said, buy an adjustable boost elbow to allow your turbo's wastegate to build 35PSI (or whatever you set, but that's a good max) instead of the stock 20PSI which is really mild. That HX35 will push cool air up to 35-38PSI and it'll take a LOT of abuse if it's in decent shape. Try not to bark it by letting off the throttle too fast.
Mod your AFC for more "fuel rack" travel.
AFC Mods - LOTS OF PICS!!!
That's how you get your pump pushing as hard as possible.
You can get to 300+HP with stock injectors & turbo with those pump tweeks.
You will really want a governor spring kit (GSK) to allow your engine to fuel above 2200RPM's because that's where the stupid stock governor springs start defueling and by 2500RPM's you're out of juice. It really sucks to drive these with stock gov springs.
No power in the upper RPM's.
If you're adventurous, advance your timing to 15-16º.
That's a free mod if you have the right tools.
Oh and I almost forgot to say... PLEASE for God's sake, use the Search feature on this site. We type this stuff all day long and our wrists get sore typing this crap out all day every day.
I'm not at all trying to offend or be a jerk, but if literally - if you scroll down the page of recent threads on any given day, there will be about 3-4 other threads (new threads) started by newcomers who want to know how to give their 12-valve power.
We all need to just start copying & pasting links or pre-written text that spells it all out every time a new thread comes up.
Maybe this will be my template.
