1 - 9 of 9 Posts
Check my mods below. Anything from a "standard" mod that I am missing?
Since I have the 2011, I have not taken off the EGR or Cooler... I have it turned off with the MMaxx ... but that is it...
Anybody have any new toys I can add to my ride?
do you have a cold air intake?
CAI, Wastegate, Studs, then you can go wild get an airdog or fass then a CP3 upgrade and then injectors. I would also get a turbo before injectors depends on the amount of cash you got in your pocket and your goals for the truck
I would consider a Airdog, Intake and studs. With the Airdog and studs being higher on the list.
^^^^^STUD IT QUICK. 625s if you can afford them. Get a wastegate.Then I have always heard air before fuel. Turbo, Intercooler, Intake, injectors, cp3 mod.
Studs and fuel filtration!
studs, and then fuel filtration, then adding air and more fuel
1 - 9 of 9 Posts
