Cummins Fan/ TECH SPECIALIST
93-88 2wd truck numbers:
centerlink DS1173
adjusting sleeve ES3124S
right outside tierod ES3122R
right inside tierod ES3123L
left inside tierod ES3123L
left outside tierod ES3122R
idler arm K7055
upper balljoint K778, K7082(HD)
lower balljoint K7025(must replace with K727 if it has 4 wrench flats and is screw in), K7025T(enhanced design), K7053T(HD)
upper control arm shaft kit K7036
upper control arm bushing kit K7006(2 required per truck), K7189(1 kit per truck, performance busings), K7104(eccentric bushing kit for more camber)
upper control arm bumpstop K7293
lower control arm bushing kit K7077(2 kits per truck), K7193(1 kit per truck, performance bushings)
HD lower control arm bushing kit K7065(2 kits per truck), K7192(1 kit per truck, performance bushings)
lower control arm bump stop K7282
sway bar to frame bushing K7096
sway bar link repair kit K7081
rear leaf spring bushing 1" O.D. x 1/2" I.D. SB266
rear leaf spring bushing 1 1/2 O.D. x 3/4" I.D. SB268
93-88 4wd truck numbers:
upper ball joint K8194T
lower ball joint K8195T
bump stop K7282
lower kingpin K992(provides 1 1/2 degree of camber adjustment)
lower kingpin bearing kit K8832
upper kingpin bearing kit K6652
sway bar to frame bushing with 1 1/16 bar K7302
both sizes are thermoplastic bushings
sway bar to frame bushing with 1 3/16 bar K6172
swaybar link repair kit K7081
right tierod ES2010R
left tierod ES2010L
draglink DS914
adjuster tube DS1411S
front leaf spring bushing front and rear SB266
i got a stack of about 20 manuals that i can get about any part number out of from different companys, everything from A/C to chassis to radiator. these are the same books that the Advanced Auto Parts uses to look stuff up. everything goes up to january 2003.
Discussion Starter #2
FEL-PRO engine gaskets and seals
head gasket 9332PT
head set w/o gasket HSU9332
gasket conversion set CS9332 (includes oil pan gasket)\
exhaust manifold gasket set MS92089
exhaust pipe gasket 60928
oil pan gasket OS34102
rear main seal and gasket set BS40633
valve cover gasket set VS50396R
pushrod cover gasket set PS50397R
valve stem seal SS70819-1
water outlet o-ring 35526
water pump gasket 35525
timing cover gasket TCS45902
anchor industries motor mounts
2wd
front motor mount 2710
tranny mount N/A
4wd
trans upper mount 2667
trans lower mount 2668
Carlson Brake Part Numbers
D250 w/ 12x2.5 drum
front
disc hardware kit H5516
pad shim kit 18063
caliper repair kit 41099
bleeder screw H9402
caliper piston 7535 for phenolic, 7501 for steel
caliper support spring H5315
inner bushing H5209
rear
drum hardware kit H7199
brake drum pro kit H2316
guide pin H4087
bolt sleeve H547
adjustment screw spring H430
self adjuster repair kits H2598 left, H2599 right
wheel cylinder repair kit 45004
hold down pin H1119
hold down spring H1164
adjuster lever H2049 left, H2048 right
cable guide/pivot H2093
cable H2104
lever return spring H2140 left, H2141 right
adjuster screw assembly H1534 left, H1535 right
D350 w/ 12x2.5 drum
front
pad shim kit 18063
bleeder screw H9402
inner bushing H5209
rear
guide pin H4087
bolt sleeve H547
wheel cylinder repair kit 45004 for 7/8" wc bore, 45002 for 1" wc bore
hold down pin H1119
cable H2104
D350 w/ 12x3 drum
front
pad shim kit 18063
bleeder screw H9402
inner bushing H5209
rear
guide pin H4087
bolt sleeve H547
wheel cylinder repair kit 45002 for 1" wc bore, 45019 for 1 1/16" wc bore
hold down pin H1119
cable H2104
Four Seasons Temperature Control Products
system specs R-12, refrigerant capacity 44 oz., oil capacity 4.6 oz for 93, 7.25 oz for 92-89
blower motor w/ A/C 35474
blower motor w/o A/C 35560
93-92 SDB709 type compresor w/ clutch S57562
91-89 C171 type compressor w/ clutch 57106
non-intercooled condenser 53298
intercooled condenser N/A
evaporator core 54108
expension valve/orifice tube 38849
intercooled fan clutch 36936
non-intercooled fan clutch 36705
filter drier/accumulator 33555
heater core w/ A/C 94619
heater core w/o A/C 94600
93-90 tensioner assembly 45844
89 idler pulley 45981
clutch cycling switch R-12 35800
clutch cycling switch R-134a 36677
coolant temp sensor 36425
low pressure cut out 35752
water outlet 85181
tranny coolers:
Ultra-Cool
light duty 53000
medium duty 53001
heavy duty 53002
Rapid-Cool
light duty 53005
medium duty 53006
heavy duty 53007
Modine Radiators, Condensors, Heater Cores
specifications
core size 25 3/4 x 21 x 2 1/4 (3row)
inlet header 2 5/8 x 21 1/4
outlet header 2 5/8 x 21 1/4
inlet connection 1 3/4 left
outlet connection 2 right
pin mount
93-92 radiator 2460
93 condenser 300034
92-90 condenser 300031
89 condenser 300025
heater core 702463, 702464
heater core specifications
702463: 8 x 6 1/2 x 2, inlet/outlet 5/8, in/out is beside core
702464: 8 x 6 1/2 x 2, inlet/outlet 5/8, in/out is above core
Wow! Lots of good info here. Thank you for taking the time to do this. I now it will be used by lots of folks.
Discussion Starter #8
give me some time and ill have a set for the 2nd gen trucks too. all that took me about 3 hours one nite when i was bored. my books stop at 2003, so 3rd gen stuff is limited, i got a buddy thats a assistant manager at Advanced and im gonna see if i can get some updated books before i leave for florida and he goes to O'Reilly auto parts.
