Rotella is a cheap oil that to me doesn't protect as well as other oils, espically when you get into amsoil and royal purple. And personally i want my vehicles to last as long as possible so i run amsoil in everything, and it gains you mpg.what in the he!! is wrong with rotella
Well I've heard Rotella has removed more Zinc so I'm looking for something else, I don't drive my truck very much I have a company truck so I don't change my oil as much as some others. I'm also trying to get away from Shell as they are foreign owned.what in the he!! is wrong with rotella
my dad has an early 70's chain saw, had amsoil in it since brand new, i had to take it apart for a class and the hone markes were barely worn. so i justify the mpg gain and the fact that it protects on startup and harsher environments a ton better, and being diesels seeing 1300* i want an oil that will make the turbo last longer. that's just me tho.wasnt trying to be rude i have 187950 on my 96 and never had any problems in my other 96 i sold it had 250000ish on it ran rotella in it as well just my choice yes amsoil purple are the #1 oils but i cant justify the $$
Well put:thumbsupI have ran AMSOIL, Mobile and Rotella in my trucks. I would say if you have the money for AMSOIL do it...but if not then I would say the best conventional oil to me is Mobil Delvac 15w-40 :thumbsup..just my opinion. If you have had good luck with Rotella, Mobile, Royal Purple or whatever then stick with it.
