21 - 26 of 26 Posts
Guess what I'm asking is if I'm seeing negative numbers on my screen the computer is to and would that not screw up the fuel mapping?? Cause the issue I was having before the new tunes was in town was grossly dirty and they are cleaner and now I've got negative boost...
Well you're only seeing a vacuum of 6 PSI at idle, right?
Has it always done this or is it new? If it's a digital monitor and it's always done this it could be the correction was set wrong or altered. They usually default to correct -14.7 for sea level, but you can adjust them as needed.
Discussion Starter #23
Yes -6psi at idle and very low boost going down the road at -2 to +2
Discussion Starter #24
Just on the new tunes I got when I put older tune in my boost reading is fine
Then I wonder if there is something in the mm3 tuning where they can alter that and your digital reading is showing the difference from whatever they messed with.
Discussion Starter #26
That's what I'm thinking told the tribe guy already guess I wait and see if he can fix it
21 - 26 of 26 Posts
