Over the course of the last 7 to 8 months I have been working with guy named Rob who is known as Diesel Camper on you tube has the transmission and engine tuning I have found while working with a near stock 3rd gen. I am not new to the diesel world and have owned all the big names at one point or another. A quick overview I was looking into just doing a few small things to my truck when I stumbled across Robs stuff online, now we fast forward to current day and I will say I am glad I emailed him. I have an MM3 tuner and Rob has 5 current tunes and an online the fly setting that will let transition without any issues at all. The tunes are a 12v, 12v with hp increase, towing, street, and an MPG tune. This comes with transmission tuning that has made my 48re transmission shift better than it did from the factory. I will stand by all of his hard work for sure and will truly say check this guy out and give him a shot if you are looking to bring your 3rd gen to life and not break the bank doing it. I run all the tunes, I tow a heavy trailer with lower egts, and will say that everything he has is worth the money. Check out his site www .mm3tuning. com
Enjoy
I am currently having rob tune my 03, same tunes. So far things are good, we are still fine tuning. No trans tuning for my truck though :(
Sent from my SM-A530W using Tapatalk
Rob aka Diesel Camper has the tunes you need! I own an 06 Mega Cab. The tuner I started with was Edge with attitude, but I was never really satisfied with the tunes-the truck always ran hot, especially when towing a 10+ fifth wheel. Dumped the Edge for an H&S minimax -they went out of business so no custom tunes; and that being said had to settle for out of the box tune. Without knowing the parameters in which the tunes were written the truck still ran hot (my guesses max timing and max fuel pressure). Finally I found Rob! He advised me to get the MM3. The MM3 and his tunes solved all my problems. Truck runs lower EGT's when towing. His tow tune is spot on, shifting is super smooth- no more banging into gear under the load. I also have all his others tunes and am very happy with all of them (they are all safe). Rob has done his homework! Excellent customer service! Nothing but praise for Rob. If you have a Cummins - you need these tunes! Check him out! mm3tuning:grin2:
I receive my tunes from rob at mm3tuning.com and I am impressed with the tunes and also the transmission tunes I no longer have the shuttle shifting on my 2005 dodge ram I have full control of my overdrive I will stand by his work 100% his turn around time is fast as well 100/100 will be referring every that I know to him thanks
