at 2800-2900 rpm at full throttle it seems that the motor misses, or defuels, or something, it will do this a few times real quick unless I back off the throtttle or tranny shifts.
Juice is on its way back to edge. smarty is set on SW#1 torq #1, timing #1, RP #2, wastegate off.
when the juice was on the truck without smarty it would set error code P0016 Crank position sensor.
Does this sensor go bad?
any other Ideas?
The BD torqloc and My viper alarm with remote start also tap this sensor wire but I have checked the connections, and I have un plugged the tap to the viper alarm.
still does this, Every time, I can make it happen on cue (if I have enough room to wind it up).
any other Ideas?
