When I have my comp box at setting 1x1 (havent tried it any higher since its been acting up), it will sometimes "misfire" and just pour smoke.. Can this be bad fuel? After everytime I run the truck my water separator is FULL on my FASS system.. But it seems (from what I can tell) that when the programmer is off, it wont do it.
Mopar1973Man.Com
Then if the problem is gone when the Edge Comp is off then the Edge Comp is the problem.
Well im just stumped because it has been working fine before today.. A fuel line behind the head has a leak. Can air be entering into the fuel system?
Not like the others......
Edge has pretty good customer service. Might be time to send it in and have it checked out and updated. :thumbsup:
Mopar1973Man.Com
Yeap... It will cause the high pressure lines to possibly drain out... :confused013:
Do you need a receipt of purchase if you send it in to Edge?
