1 - 20 of 38 Posts
Found a 94 for 1800 dollars has a new trans and new lift pump and its in good shape can get it cheap but the issue is it runs for 30 mins then it will die I can't find any info on this I was thinking something like the fss and or the IP ??
Sent from my A110 using AutoGuide.Com Free App
After it dies how do they start it back up? Do they have to prime the fuel system again? Is the fuel filter empty? Even if it is the IP, that is a heck if a deal and I would take it either way.
Sent from my Android
That could be something as simple as a clogged fuel filter. When it runs long enough it finally craps up and stops running. That can happen if the inside of the lines or fuel tank is rusty or filled with gunk.
It could have an air leak. It is also possible the shutoff solenoid is going bad. I would suspect fuel flow issues from a prefilter, to the filter, to a lift pump, to the OFV, to the lines. I once had a car with rusty lines or fuel tank. The fuel filter would fill up with gunk. Then the car would stop running. If it sat a few minutes it would start again and run for awhile. When that happened I would blow back through the fuel filter and stop at the part store for another.
No I don't think he had to prime again from what it sounds like he would wait till the engine cooled down and it would start again I'm really really considering going to get it I would like to have a p pumped Cummins along with ve pumped one too I imagine the 94 has the cold start advance too o I'm almost wondering if that sensor is screwed cause doesn't that sensor supply the fuel solinoid with power and the two are intertwined somehow and from what it sounds like when the intake temp get over that set temp it shuts down as far as air in the lines goes I don't think so wouldn't it just stall randomly and miss ? As far as the rust or plugged fuel filter I would think when he did the lift pump the tank would have been emptied and cleaned and fuel filter changed.... one would think.. hope
For the price I think I should buy being as I know in parts its worth twice that but I'm just afraid its the IP but who knows could be simple
Can a person rebuild a p pump themselves ?
I'd like to buy cause I'm really turning into a diesel nut lol
i say go for it. if you know you can make your money back in parts then hell its a win win. easy fix, you have a bad a$$ rig for next to nothing. not so easy fix, you part it out if you have to and make money to put towards a better one
Well I've already got a 93 in the pic there that crecab is being converted ATM but it would be nice to have two I think I'm going to buy her fak it I'll make money back if it flops or have an extra trans and parts hopefully I can figure it out
where in alberta? i have a 94 dually 5 speed manual and might be interested in parts, or the whole truck if your not.
I'm eAst of red deer in Stettler ill let u know what happens here what kinda parts u lookin for ?
Discussion Starter · #9 ·
So from what I found its gunna need a ip or so my research points too I tryed to get him down to 1200 but he is stuck on 1800 ...hmm
· The 10th Man
What makes you think IP? these IPs are pretty much bullet proof, the 94-95 have a problem with the barrels warping but that's not what your problem is. I would say it's fuel related, or the FSS is loosing power but either way it should be under a $100 fix if not $10.
Discussion Starter · #11 ·
my fist thought was the cold start advance or auto shutdown solinoid something electrical trucks is a friend of a friends truck and its cheap I got a few bucks I would like to have two diesels and my dad wants to cummins his 95 chev dually so if it does end up being the ip I could sell it to him and he could get it rebuilt for his truck
keep yakkin fellas, like a bunch of geese and some fox is gonna slip in there and buy that from under you.
Discussion Starter · #13 ·
I don't think so its not even listed for sale I was out at a friend of a friends and seen it and asked about it and he asked if I wanted to buy it
Discussion Starter · #14 ·
Besides that comment u have any suggestions what could be wrong with her ?
· The 10th Man
These trucks don't have a "cold start advance" the only cold weather thing they have is a grid heater. the "auto shutdown solinoid" is the fuel shut off solenoid,
If the truck starts then it's not the "Pull" wire so it's either the ground (not likely) or the Hold wire but you can do a test easy.
Turn truck on and and wait for it to turn off, feel under the FSS to see if the lever is up.
Here http://www.cumminsforum.com/forum/9...8-fuel-shut-off-solenoid-fss.html#post5938135
Discussion Starter · #16 ·
Thank you ! Very informative c I've been learning about my 1st gen and wasn't sure if they were the same again thanks man
Discussion Starter · #17 ·
So basically wjat you are saying is if the fss is closed and the key is still in the run position it's a fss issue ?
Discussion Starter · #18 ·
Was texting owner he's claiming its got new fuel relays but didn't specify
· The 10th Man
yes let it run and then when it shuts off see if it's still up without touching the key
Well there's a Pull relay and a hold relay. and it could also be a FP problem, really I would be suprised it you had to put more then $100 into it to get it going.
damn dude, buy the truck! you could part it out and make double that. hell, 12v's are going for 2k right now!
1 - 20 of 38 Posts
