i have a 2007 3500 5.9, i have the diablo powerpuck with the 50 and 90 hp settings, i have the guages now, k and n intake and plan to straight pipe from the turbo back. can i put it on the 90 hp setting and just put it on the floor or is that gonan be too rough on the motor. do i need bigger injectors? i already tripped the 1-3 cylinder banks error code on the 50 setting. any idea or input would be great.
stock injectors are fine for that... im running stocks on the smarty and dont throw any codes :peelout
better get a rail and fuel psi gauges.....and if you put it on the 90 h.p. setting you will see(if you had a rail gauge) high rail pressures.it will help you spool faster also.i wouldn't dog on it to hard 'til u get the fuel and rail gauges. if i am wrong someone please chime in and set everybody straight.
I run my predator on level 4 with no troubles. I don't have a fuel psi gauge, but thta is on the list. Just watch your egts. Level 4 is advertised at 160 horse, probably less, but more than your 90 horse setting. U should be fine.
Never had a problem yet with mine. Only use the 50Hp set. No need for the 90. No codes and run 50 every day all day with no problems. Notice a slight milage increase too. just My Opinion.:beer
