i just had a max spool 2 cam installed in my truck. the results are really noticable. cruising boost is higher. 4-6 lbs. mid to top end range power is really where the cam shines. egts are down alittle. i havent figured it out with my truck yet on why there so hot. egts fall like a rock when you let off at hard throttle. the sound is really diff. lot deeper toned exhaust note and idle it sounds so good. cant hardly here the cummins rattle. let me know if you have any questions. :thumbsup:
its from gus at fbd. you would have to call and ask him.
how much does that run if you don't mind me asking and did it help mpg
i would say you would spend around 1400 for cam and install. i dont like to give out exact prices of vendors or sponsors on here. mpg should go up idk really bc ive only had it for 3 days. ppl say a cam is mainly for performance.
Power Hungry
Im not sure if you know but Do you really have to chop up your front end to install one.
Im not home to really look at it and tell.
But mpgs should go up but it will be hard to stay out of the throttle.
mainly cause Cummins builds theirs for emissions not for mpg or power.
haha my bad didnt realize how old the tread is lol.
