2000 dodge ram 3500 4x4 with titanium fass. Other than that the truck is stock other than I'm currently putting gauges on it. Truck is running and cuts out randomly but doesn't die. Just goes back to idle. If I push it to the floor the truck feels like it barely has any power. I tap the throttle a few times and then the throttle response comes back. Am I looking at a map sensor? Only code I have is 1693. Just put a used VP that my buddy had in his truck he was parting out. Pump ran fine in his, and I just pulled it and checked everything and it seemed fine. Didn't have any problems for the first few miles. Recently replaced my TPS as well. I also replaced this sensor about 8 months ago with a napa part. Haven't hooked the truck up to the tablet scanner yet but I've read threads from people having similar problems and it being the map sensor. Any wisdom or help would be appreciated. Thanks!
