1 - 3 of 3 Posts
so today i gutted my stock intake tube going from the air box into the turbo and popped my silencer ring while i was in there. after putting it all back together i took it for a spin "sounds badass by the way" and my truck threw two codes
P0107 map sensor low
P0073 ambient temp high
i limp it back to the house and find that my air filter is absolutely filthy, brown and u cant see a bit of day light when held up to the sun. im guessing the codes were thrown by that sense turbo is breathing a little better now and demanding more air. im assuming when i replace the filter and blow out the map sensor a lil bit it should be fine right, what do yall think
by the way, i am also assuming the map sensor is what is mounted in the top of the stock air box, any info would be great
:blues:
The sensor your talking about is the intake air temp. The map sensor sits in the intake on the head just behind the intake horn. Two small screws and a three wire connector.
Get a new filter, clear the codes and see it they pop again. Both are real easy to change. I have never heard of an IAT sensor going bad though...
1 - 3 of 3 Posts
