1 - 20 of 24 Posts
trying to help out a Friend who has a 08 running a late 5.9 manifold and Phatshaft 66 with a 5" TBE system that's all junk/rusted/broken IE needs replaced. Can a turbo back system from a 10+ bolt up correctly with the different manifolds ?
Hi 2010 exhaust with a 6.7 that was made for a stock truck with a HE351VE VGT turbo have a different turbo flange/down pipe. I think he will need a downpipe made for a Phatshaft 66 i think its the same as a s300 borgwarner flange but you will need to check to make sure, i would think that he could find a complete setup for a Phatshaft 66 he will just have to look around to get the right downpipe kit.
he's contacted Industrial Injection about what issue he could have and they haven't responded to email and he couldn't get anyone on the phone as of yet.
Hi does the truck have a cast elbow off the back of the turbo or is it downpipe right off the back of turbo?
Hi if it has the elbow any 2004.5/2007 exhaust kit should fit. Here is a picture of the stock 2005 elbow.
Thanks for the picture. His does look a little different, it really sure how to post a pic up here anymore since photobucket changed
Is that 5 inch all the way including the down pipe? I wonder if that is a stock elbow just rotated different it hard to tell from that picture?
here is some better pictures of a stock cast elbow. Turbo side has little pins and closest to the clamp in the pic.
The more i look at your picture i don't think that is a stock elbow on his truck. I don't see the cast notches on the side like a stock elbow has.
Discussion Starter #14
i'll try to have him get a picture from under the truck looking at the down pipe and that elbow to get more clarrification
Discussion Starter #15
The elbow is a holset.
The new down pipe bolts up without issues. Without any instructions it presents a challenge. But will hopefully finish tomorrow. Rear fitment for the Y pipe and connecting pipes is becoming a struggle
Hopefully pics tomorrow night
Hi glad you got it figured out. So it uses a cast elbow from a 2005/07 5.9 or is cast elbow from a 2008 6.7 up? I would guess it's a 2005/07.
Ducati M.
The 07.5+ Cast elbow uses an hx40 flange, which is also what most s300’s are cut to. The 03-07 flange is a lot bigger than that. Just FYI.
Dman i know a 2004.5 to 07 5.9 turbo is a bigger outlet. So even if it was a 2008 with 6.7 vgt turbo with a cast elbow the outlet flange would be hx40? I thought a vgt had a different outlet than hx40.
Ducati M.
All the 6.7’s use the same turbo. In 13 they changed the electrical connector, and name, but nothing is different dimensionally.
so all vgt turbos have a hx40 then, i didn't realize that.
1 - 20 of 24 Posts
