Hi-
Do any of you know the service intervals for the main and rod bearings for the Cummins 5.9l 12v? I have heard they should be rolled out every two hundred thousand miles? And has anyone performed the task of rolling out bearing while the engine is still in cab? I have heard of the cotter pin technique, but never tried it myself. I will have the pan and front cover off the truck next week and i'm debating if should just put some new bearings in along with the colt cam and new tappets. Factory bearings are actually pretty reasonably priced 120 for mains and 117 for rods, standard size of course. My rig is about 240,000 on the odometer currently, so i guess i am a bit over due for the bearings and a head gasket? any advice would be appreciated! thanks in advance.
