1 - 4 of 4 Posts
any one know if there is a heavy duty lowering block that will work with the 70 in my 350 looking to bring the down to match the front's stance a little, let me know if you guys know of anything, thanx
is it leaf on top of the axle or under the axle? if its on top of the axle you cannot use a block to lower it.
if its under the axle just get a decent steel block not aluminum
Yeah the factory blocks should be on top of the axle. You'll just have to make or get a block that's shorter than the factory one. Aluminum blocks work just fine. Just stray away from any block (steel or alum.) that is a cast variety.
1 - 4 of 4 Posts
