I have a 96 dodge 2500 4x4 with a manual. Ever since I bought it a couple months ago it has seemed to have some power issues. I put guages on it this weekend and found that I have low boost. I can only pull 14 psi full throttle and it takes about 1/2 mile of full throttle to build that much. At cruise no matter the speed my gauge reads 0 psi boost, and upon romping on it, it takes a quite a while to build boost. I have read alot talking about boost leaks and such and built a test cap to pump up the air charging system and found a couple leaks but they seem to be very small.
The leaks I found are
wastegate actuator ruptured (capped of line)
intercooler boots have very small pinholes
I also hear air going down the exhaust just a slight bit. I pumped it up both with the intake horn hooked to the engine and with it capped off. I have sprayed everything liberally with soap water and am having a helluva time finding a leak that amounts to much. My exhaust is wide open, no restrictions and no intake restrictions, new filter. Any suggestions? I cannot find ANY leaks that amount to anything but the air is leaking out fast but I cannot hear it, and I can normally pick up leaks.
