Hello. I have a 91 D250 with auto trans, VE injection pump, 98k original miles. I have a very low idle when the engine is hot. The problem usually occurs when towing or after a long freeway drive during hot weather. When I stop at a light (still in gear), the idle drops so low that I lose all oil pressure. The idle improves if I put it in neutral or park. It has never stalled, but it barely runs and is a bit harder to restart if still hot. However, it's fine after the engine cools for a while. I have no other symptoms and the truck runs great overall. It's only an idle problem. The problem rarely occurs during the winter.
What's could be happening here? It has a newer lift pump and fuel filter. The valves and idle speed were recently adjusted by a Cummins shop. I also checked the electrical connections on the solenoid, temp sensor, etc. I don't know? Any help would be appreciated. Thanks.
