1 - 3 of 3 Posts
So my truck drove fine all the way to work, sat the normal 8 hours and when i got in to leave at 3:30, it started and made an awkward sound. Right away i knew something wasnt right, before i could shut it off it threw a cel. read the code, cant remember exactly what it was, P0192 i believe, programmer was cold and all i could make out was low fuel pressure. Popped the hood, no fuel, no oil, checked under the truck, again no fuel or oil. Anyone have a similar problem? Been driving on smarty sw5 for over a year now and now problems. Could the stock fuel pump finally crapped out on me?
192 is low rail pressure sensor voltage. You should check the connector first. Are you running any fuel additives?
nope no additives. Trucks at the garage right, now, kind of panic when it happened, going to have them check the regulator on the injection pump first, could be the connector, been snowing alot lately.
1 - 3 of 3 Posts
