1 - 18 of 18 Posts
hey i have a 2002 dually with 24v cummins and i have had an issue with lower then normal fuel pressure @ idle and higher then normal EGT on idle any ideas i have changed the lift pump for fuel pressure and it worked for a few hrs and thenn it went back to the same thing it does have a edge juice with attitude any ideas please help thanks :confused013:
What kind of lift pump is on it?
Since its a stock lift pump, Its not enough to support the fuel demands of the Edge. What is your fuel pressure at right now? If its too low you will starve the injection pump which is the last thing you wanna do.
it is a stock replacement
There's your problem. With the Edge programmer turned up to Max it will burn your VP up from a lack of fuel pressure. $900-$1500. For a new VP-44. You need a better liftpump asap. Check out dtt asassin, Fass, airdog, Raptor. :thumbsup: You need atleast 15 psi but a lot of guys shoot for 20 psi at idle and no lower then 10-12 at wot.
Cummins6sp5.9 is exactly right. Theres no way the stock pump will keep up with the Edge. I personally would look into a FASS or DTT Assassin. The new AirDog pumps have been having some issues.
Reactions: Reidie_09
I would say yes...its causing them to run hotter. Get a better lift pump on there as soon as you can.
· Mopar1973Man.Com
You might want to verify with a mechanical gauge its been known for electric gauges like Edge Juice to fail and start to skew up or down a bit and read false numbers after water hammer damage has taken place to the sender.
hey thanks for all the info guys i will try and them all and see what hapenes
thanks again for all the help
No problem:thumbsup: Let me know what lift pump you go with and your results:thumbsup:
Discussion Starter · #15 ·
hey guys thanks again for all your advice jus orded the FASS system and new edge juice with attitude found out my old one was NFG soi am hoping to have all that on the truck in the next few days and we will be roalin some coal again thanks again every one for the help greatly appreciated :thumbsup::thumbsup:
1 - 18 of 18 Posts
