Have had this problem for quite a while on my chummins. Well basically always since I did the swap 6 years ago. The engine won't get up to normal temp. I have a 40 minute drive to work, mostly highway 60mph, temp gauge barely moves by time i get to work. Driving around town it really won't heat up unless it's 90*+ out and I'm in stop and go traffic. Then it'll maybe get to normal temp once in a while.
I've put 3 genuine cummins tstats in it over the years thinking one may be bad. Last time was last spring after a head gasket & studs install. Same results. I can temp the engine all over with an IR gun and maybe get 140-150 after pretty much any amount of normal driving. Temp gauge in the cab reads similar. I run it the majority of the time with the engine fan off the engine because even without it, it still won't get hot. The engine has the normal tiny little bypass hose that goes around the tstat. And other than that just the normal hoses going to and from the heater core. Water pump is a couple years old. Problem was there before and after changing the water pump.
The only time I've gotten it to heat up and run at normal temp was earlier this summer in 95* heat pulling way way too much of a load. A 14k skid steer on a 7k trailer, running 4th gear at about 50mph. Even then it only got up to normal temp about 190*.
Truck has a first gen radiator and first gen intercooler in it. Not sure what else is relevant. Thanks for any ideas. Would be nice to get it to warm up a bit since winter will be here before we know it. And it barely gets warm enough to heat the cab even with no fan and the radiator blocked in the winter.
