1 - 20 of 22 Posts
How much boost should I be seeing with the Smarty on level 5. The software is the most recent one avail. (Revo). I am seeing @30 lbs.
I wanna go fast...
I am not positive, but that sounds right without a boost fooler...
I wanna go fast...
Can you do that with a Smarty? I have no knowledge on them...
my dads got and 06 and he hits 30 without a fooler. my 07 get 35lbs
Yes and i still get max 36lbs.... Is that the most boost im going to get with my mods.
That seems kinda low even with my meager juice/ramifier stack I can see into the 40s...
I thought 30 - 35 was very good for a stock turbo
30-35 psi is good. The stock map on a 04.5+ is in the range. But with a boost fooler an 04.5+ should hit in the 40s with the right amount of fuel...granted the turbo is not the most efficient at that range but it can hit it.
Stock Turbo I Get 38 Psi With Out Boost Fooler.
Stock MAX on mine according to the Banks PDA is 39 lbs
818
I thought the smarty did boost fooling, at least that was told to me by the smarty reps.
Smarty will boost fool up till 45psi when you have the wastegate turned off on the new REVO or if you have older software you need to use the aftermarket turbo programs.
mine hits 45 psi on level 2 of my quadzilla and 48 with level 4 to the floor
1 - 20 of 22 Posts
