I have the same issue with my HX40 about 26 PSI is all i can get out of it. Piers Diesel told me to block of the wastegate and see if that helps, havent done it yet but you may want to try that.O.k just finished the break-in miles of my D-tech turbo (150 miles). Edge set on 4 at WOT can't get it over 27 Psi (according to my display) All boots are tight. So i'm guessing in need to adj. the wasegate arm. I know when I installed the turbo the threaded part was all the way out before I locked the nut. Do I need to take off the clip on the wasegate arm and turn that one out too or ????.:confused013:
Thanks
