1 - 2 of 2 Posts
My low beams will not come on right away when I turn the switch. Fogs and every thing else is fine. a few times I started to drive just using the fogs and they came on after a short distance.
I have searched the forum and have yet to see a solution to this problem. I suck with wiring so any help will be much appreciated.
Thank you.
Discussion Starter · #2 ·
Think I found the problem. Turned the light switch on and moved the steering wheel through the tilt motions and they came on and stayed on in one certain position. Pretty sure I have a broken wire in there. I can see why as I tilt the wheel all the way up every time I get out of the truck.
1 - 2 of 2 Posts
