1 - 3 of 3 Posts
Hi guys. I have a 95 regular cab nv4500 that makes a horrible banging/clanging noise when engaging the clutch. It doesn’t do it all the time but when you push in the clutch after letting off the throttle at low speed it shakes the entire truck.
It seems to also do it if your driving down the road and let off the throttle abruptly (not touching the clutch) it shakes pretty bad. I was able to get a few videos below, any ideas? I noticed the rear differential and leaf springs move around in sync with the banging sound. Thanks
Loose flywheel bolts. Loose pressure plate? I would pull the trans and check out the problem now not later.
1 - 3 of 3 Posts
