1 - 10 of 10 Posts
Hi,
I cant find the usb cable for my MM3, and it seems more or less impossible to get a new cable here in Norway.
Is it possible to use adapters on the MM3 from micro usb to like usb C?
Hi,
Sweet Jesus, micro-usb cables are a dime a dozen here.
If you need one I can ship you one.
I dont know if I should order a Egt for the MM3 or if I should just use my Edge. Guess they might have the usb I need too.
But thanks for the offer.
Micro USB is an extremely common cable. There are still devices that use that cable to charge so any store that sells cables should have one. Heck, the gas stations here have them.
Well they dont over here, can get a cable with micro usb in one end. But not in both ends. Found 1 cable on a webshop in Norway that hade micro usb in both ends, but that was only 8" long. :sneaky:
Ok that's different. This is my ignorance on the MM3 platform, but why would it need a micro USB connection on both ends?
Now I know why you can't find one. That's not a cable that's used for much. In fact, I've never seen one in all my years in IT.
No I`ve never seen one myself, but the MM3 uses one betwin the computer and the screen.
But I`m thinking about switching the Edge insight I have and just use the MM3 screen, if I do I need to order a egt anyway guess the once that have that would have a cable for me too.
So the connection on the PC would just be a regular USB cable.
This place seems to have every kind of cable you can imagine.
Discussion Starter · #10 ·
Reactions: panteragstk
1 - 10 of 10 Posts
