92,intercooled,slight pump turn up,lately a loss in power,struggles to make 10lbs of boost when it used to pull18 no problem.Where should I start looking?Air filter is clean,nothing obvious visually under the hood.
1ST GEN
Have you replaced the fuel filter???
If that don't help you could pull the intake tube off turbo,check for shaft play,if there's any,take another minute to pull compressor housing off and check for scrappage.Or a boost leak.Or lack of fuel.Have fun!:lol4:
Thanks for the tips,its seems that the fuel filter was the culprit,I guess I should change it on a more regular basis!:doh:
The other thing to watch for are leaks in the intercooler and the connections.
