1 - 4 of 4 Posts
I have 1998 12valve build date of november 1997. I m curious how do I tell what injection pump I have. I know I have a 215HP pump but curious if its a 903 or not.
I also want to know everything that can be done to my pump I have #0 plate hair back from full forward, AFC full forward, I am curoous about like mack plug? I know dv's planning on GSK in the next week or so.
Its on the driver side of the pump behind the brackets. To check it just spray some brake clean and use a little mirror. Mack plugs won't allow more rack travel on a 215 pump, keep the stock dvs in it and get a 4k and 60lbs.
The numbers your after are the last 3 in the 2nd line.
what is the difference in pumps? not all 215hp pumps are the same?
I'm curious now too. Thought all pumps with the same hp were the same pumps.
1 - 4 of 4 Posts
