81 - 100 of 251 Posts
Discussion Starter #81
Here is a shot of the cab floors, nothing real bad, caught it just in time.
I asked in another thread about bedliner, bought some UPol two-part berliner to spray on this once I get it patched and the rust sealed up.
Sent from my SM-G950U using Tapatalk
Discussion Starter #82
Here's a some shots of my wiring cleaned up...it's taken some time. Still trying to clean it up...got about three more short runs to cover with loom and get secured.
Discussion Starter #83
And, if anyone can tell me, what would have been mounted on the inner fender that would have ripped those holes?
Looks like where the cruise control servo mount fixes
Here is a photo from google
Discussion Starter #85
You can see those dimples in mine (that aren't drilled) for cruise (mine doesn't have cruise), but looking at that photo; it had to have been something owner installed that was since removed.
Discussion Starter #86
Pulled the seat, door seals, and the door panels today...pulled all the trim and headliner last night. I'm running without any headliner or trim, I like the utilitarian feel; but now I have a batch of screw holes to fill. Probably pop the windshield and back window and cut in the cab when I get the floor done.
I'm going to grind the little bit of rust out and get it coated with Gemplers rust converter then fiberglass the holes. Should be at least ready for fiberglass tomorrow night...then sand and prep for bedliner, then cut in the rest of the cab in black.
Discussion Starter #87
I've determined this truck was fully loaded at one point in its life...I found all the wiring for the mirrors, windows, and locks cut off and stuffed into the jamb on both sides. I have no idea what the POs did to this poor truck...but it's making sense now, white doors, black cab. And I found a sticker on the one door with a different VIN, like from an auto salvage. I'm going to pull all that wiring back into the dash and terminate everything with heat shrink in the even something still has power.
The rust converter has to sit 48 hours before top coating, so I worked on my brake light issue...two issues, rod too short and the bracket had loosened and allowed the bracket to rotate back. I didn't realize there were two adjustments for the brake light switch...
I also addressed the driver's fender that had suffered from either a battery boil over or a battery blowing up. I slathered rust converter on that and will paint it next week.
Discussion Starter #88
Well, I got my plans changed...been ordering parts, no time to install.
Hopefully this week I can get the cab floor done, and get that back together...I'm possibly going to forgo popping the windows until next year in order to get it on the road.
I have to finish tweaking the MC and booster rod length, install a vacuum pump, finish some wiring, kill the KDP...I have the parts, need the time.
Discussion Starter #89
Well, daughter (she's 11...) was all for pulling the glass, so we fiberglassed the holes in the floor and pulled the glass. The drip edge is rougher than I thought, I have some holes in the roof (probably moisture tryin to get out). So I rooted out the scale, slathered the rust with converter, and primed...
The windows popped out ok, they never used sealer on the rear and that's why it leaked. The front sealer was spotty...and was possibly leaking...it isn't the vents in mine, maybe the cowling is cracked?
What does everyone use for seam sealer? What about gasket sealant?
So when I hit it next, fiberglass in the roof, seal the drip edge, prime it, cut it in with field drab or black (it's going woodland camo), and push the windows back in...then it will be the floors!
It's coming together, slowly...
Discussion Starter #90
I ordered seam sealer from Eastwood, ordered self-etching primer and more Aervoe dark green and black as I'm thinking this thing will be painted this fall.
Good luck going down the paint rabbit hole!!! The colors sound really awesome too
Discussion Starter #92
I'm going to base the color scheme on the three-color woodland camo with possibly some fourth color splotches. I found a military "template" based on an M880, so the overall truck it's based on is similar.
I know the paint is a pain...but this isn't a show piece, and flat colors should hide most of the body imperfections.
Discussion Starter #93
Some of the work my daughter and I did tonight...I did buy a cover...
Discussion Starter #94
We got some more sanding to do, but I think we may just need to wash it out with soap and water to see what's left.
I do need to get lacquer thinner to wipe it down with, then primer it, and start cutting into the roof and A and B pillars. The floor will be last...
Discussion Starter #99
Pictures after second (and final) coat...
Now for reassembly...
Discussion Starter #100
Got the back window in, broke the windshield putting it in (grrr, I've never not broken one on install), installed the door gaskets, and painted the 4wd shift level and surround.
Does anyone have a source for replacement 4wd shifter boots? Mine is getting bad...
I bought a 1st gen seat for $40 to replace the 2nd/3rd gen "upgrade"...just need a cover and four nuts to install that.
