go to the 1st gen performance section at the bottom
Thats some good numbers if that is all you have done! One big difference between you and me is the fact you have a manual tranny. You transfer a lot of usable power that I loose thru the drive train. I'm a little over 400 with about 1000# of torque and you can see in my sig what I've done. The higher you get in HP, the harder it is to get more of it!get yourself a set of pod injectors play with your pump grind your fuel pin down and you will be pretty close that is just about what i have done and i'm at 370hp and 780tq
