Hey guys i figured i would share my findings from an on goin problem i have been having.... Quick recap, Last summer about one month before i purchased my Silver 64 my stock charger started to making only 26psi at full boost when it used to hit 32psi all day long.. Well since i was already looking into buying an upgraded turbo and after i put new IC boots, Clampco clamps, new afe filter, grid heater gaskets and everything i fiqured maybe this would have fix my low boost problem... So once the new turbo was on and it was providing 45psi of boost i thought everything was ok cause i was just running the smarty (which boost fools to 44psi).. But after the addition of the Quad Boost fooler, Cfm+, II Cp3, and MP-8 and still only seeing 45psi of boost
it really started to set in that i was having some sort of problem and it needed fixed!! I didnt want to continue to keep throwing money into it and just hopping it would fix it so my first step was too make something to pressure test my intake system... So at work yesterday i fabbed up this custom intake pressure tester (pictured below) and used my stock IC boot and a reducer PVC pipe to mount it to the compressor housing.. After my first test and about 5psi reading on my guage i started to hear air pouring out by my intake manifold and after a closer look i found that i blew my Intake Manifold Gasket right behind the feed line goin to the fuel rail... I was actually shocked that the amount of air coming leaking out couldnt have been heard.. But i am so releaved thats all it was, and the gasket (which is $12)will be here tomorrow
arty018: Pictured below are some photos of my Pressure Tester, it mounted on my turbo and the last photo if you look closely about 1" to the right of the Map Sensor you can see the gasket sticking out.. I will post my results after the intall of the new gasket tomorrow... Thanks Shawn
