1 - 11 of 11 Posts
I have a 2005 common rail, when the truck is cold it starts right up, when the truck is up to tempature I shut it off and try to start it up, it will crank for 4 seconds then start. ANYIDEAS!!!
First World Problems!
You can try retorquing the feed tubes first as it is easy and free. After that if your problem isn't solved I would start looking into the injectors.
:agree2:........
What about that rail pressure realease valve
Any where on the low pressure side (lift pump) and high pressure side components are possible not to provide/hold the pressure.
Any trouble code???
2005 cummins 4x4 I want to do 20x9 cd hoss with 35x12.50 tires. What size lift will I need???? Thanks
^^^:umno:... I've seen this post as both a topic and now a hijack. :spank:
1 - 11 of 11 Posts
