Middle harness. Orange wire w/black tracer (might be a navy blue).
Torque Converter Lockup Switch
for 1996 - 2003 Ram Diesels
(except California vehicles)
The addition and use of a torque converter lockup switch can improve 0 to 60 mph times by 3-5 seconds, improve your ability to stay in higher gear when pulling heavy loads, and improves braking in 3rd and 4th gears when using an exhaust brake. The following diagram is supplied at no cost or obligation. Note that use of this method of lockup may be hard on vehicle drivetrain and may void vehicle drivetrain warranty. Use makes vehicle drive like a manual transmission in 4th gear such that vehicle may/will stall at low speeds/stops if lockup is not disconnected.
Note: Some 1996 automatics require computer to be reflashed by dealer for the lockup switch to work.
Step-by-step Instructions:
1. Install jumper wire in place of the trans relay in the Power Distribution Center (black box behind driver side battery) as shown in diagram below. This jumper wire will supply 12 volt positive to the transmission torque converter clutch solenoid. This jumper will be electrically hot thus it should be installed so as not to short against ground.
Note: The position of this relay changes from one year to the next. Consult relay location chart on inside of relay box cover.
2. Install ground wire from the B11 orange wire with black stripe to a switch or relay such that the ground source can be turned on and off. The B11 wire is located in the middle computer connector located on the firewall behind the air cleaner.
