0216 it failed VP44. That is the death code for failed timing piston in the VP. It will get worse until total failure in short order. Got my last one from O'reilly's with lifetime warranty with a filter change and free fuel swab test provided. From Standard motor parts. list was $1550. No shipping and local or overnight usually. You can work some discounts for price match or veterans etc. Just about anybody can get at least 10% off, price match more. Takes 2-4 hours and only special tool is 10 dollar gear pull disc and if available a 3/4 tubing wrench for injector lines.
I am going steelhead fishing for a few days, will be back to help later in the week.
It is a mechanical failure , not an electrical one.
P0216 VP44 Fuel Injection Pump Timing Failure
DTC P0216: VP44 FUEL INJECTION PUMP TIMING FAILURE Monitor & Set Conditions Fuel injection pump operation is monitored with ignition on. DTC will set when the engine speed is greater than 300 RPM, fuel command 5 mm3/str and timing command within a certain window. Possible Causes Other DTCs Fu...
mopar1973man.com
