121 - 136 of 136 Posts
If the 6.25 pulley was spinning 2000rpm, the 5.25 is going 2381. I would wager the weight loss will go unnoticed from the extra work being done. But if you need the speed it's a win win.
yea, I needed a 6 rib with a shoulder since I shaved two ribs off mine to make it a six rib, I lost the shoulder on one side. Maybe it will boost the steering and brakes as well?
TECH SPECIALIST
Discussion Starter #122
Bought a 2012 pump with no pulley and ordered up a Beans pulley for this pump. Not expecting any change in throttle response with this since the pump that is coming off is worn and probably does not provide a whole lot of drag. 435k on this pump, I can say I got my moneys worth out of it.
You'll like that new pump for the improved steering and braking! I still need to swap out mine for the latest remote resi pump.(y)
TECH SPECIALIST
Discussion Starter #124
Yeah looking forward to getting it in there. Probably by next weekend.
That's a thing of beauty right there.
TECH SPECIALIST
Discussion Starter #127
yeah it is... looking forward to getting it in there with a new pump. i did not mention it here but already installed a new pump only to find the shaft wobbling. pulled it back out and reinstalled the original pump. have another new pump in hand ready to go, need to find new crush washers for the banjo joint and in it goes.
TECH SPECIALIST
Discussion Starter #128
Installed...
New Pulley, Bean Machine = 1.3#
Installed on new pump
Mounting the pulley flush to the shaft
Fitted in the truck using the OEM hose from the old pump, not the banjo style (belt not tensioned). I did not catch that this was the wrong pump (non-banjo) before the install.
That's a pretty significant drop in weight almost a full lb! I still nee to try my 6 rib hellcat pulley that is only 8 oz.
TECH SPECIALIST
Discussion Starter #131
Yeah I cant say that I feel that change in throttle response, but I hear it. Timing rattle now under certain conditions whereas before the install I had none. So I get to tweek the tune next...
The new pulley for the 08+ pumps is lighter than the original you had. Weighs about 1.5lbs.
For the massive difference in price, guess the question is would .2lbs be noticeable. Specially when the newer 12+ pumps come with the new pulley already installed.
906697
I have a new remote resi pump that pulley weighs 1.135 oz, so almost 2 lb. I just weighed it this morning.
My 6 rib pulley is only 8 oz it adds up fast when you delete all the extra idler pulleys.
Hm unless the dorman is lighter I find it hard to believe. I weighed my dorman off my 08 style pump and it was a hair over 1.5lbs.
TECH SPECIALIST
Discussion Starter #136
my pump did not come with a pulley...
Also, the one I installed was made in USA vs China. Happy to support US businesses.
