K so i need to put a set of front coils on my 02, but can i get away with a 4 inch lift spring on it without needing the new arms, i have the heavy ranchhand on it so it sags it down even with the leveling kit...
If you can cram them in there and have it still sit 2.5" over stock then yes, you can "get away" with it. No problem there.
Think about overall lift height. If it sits where it should with a leveling kit, do you need arms with a leveling kit? Sounds like you could benefit from a stiffer coil up front actually.
G
yes i beleive they do i actually think mine has them since before i bought truck it had a snow plow on it they make a heavier spring stock height for people with snowplows not sure where to get them but my front end doesnt sag whatsoever with the ranch hand on the front
