I'm guessing you have the canister mounted lift pump? Just a switch to a stock in tank pump should be plenty fuel for 700+ hp.
Pumps leaking, pumps going bad, melting fuse in harness, cant hold pressure....What have been the huge issues with the airdog? I heard it was mostly due to the filters not getting changed and the ball thingy not getting cleaned.
That's what i firgured lolyeah, they sold out and QC went in the toilet. :thumbsup: +1 for FASS
Nope. Stock pump, stock lines, everything. Just as long as it's not the canister mounted lp then it's good to go.It was mentioned that the stock intank lift pump can handle 700 horse. Does that include some kind of intank mod?
No all 06's are in tank pumps. Only 03 and maybe 04 had the canister mounted ones.But regarding the canister lp, aren't all 06's canister type??
Oops. When you said canister, I was thinking intank module. If the stock lp is capable of such horsepower why are so many upgrading to fass or airdog?? Came across a cat 2 micron Donaldson w/s kit that sounds interesting.No all 06's are in tank pumps. Only 03 and maybe 04 had the canister mounted ones.
