Hi, I have a 91.5 D250 Cummins that I've had for about 2 months now. It has a newer lift pump but someone had it wired which looks like directly to the fuse box and ignition and theres a wire I have to plug up to get full power to the ignition. But when you turn the key on sometimes the pump runs and sometimes it doesn't :shock:. The truck usually starts right up and runs great but losses power after 10 minutes of running. It's like theres a short in the lp wires and the pump turns off. Any ideas on how to wire it better maybe directly and should the lp cycle every time with the key or only sometimes...
Please Help :thumbsup: Thanks
