I just did the APPS adjustment and reset a few days ago. I'm a little concerned now that the lift pump doesn't run when I turn the key to the on position prior to starting. It always did prior to the APPS change. With the key on prior to start, the pressure says it's at about 1 psi. The fuel pressure sits at about 13 at an idle so the pump must be working. I didn't the two were tied together is this a coincindence? Is it OK?
Thanks
Thanks
