I just recently bought an 01 the guy who had it before me had a fass 150 and took it off, he said he had a new stock lift pump put on. In the first couple hundred mile I had to put new o-rings in the water seperator valve and a new banjo sealing washer on the bottom of the fuel filter canister(I assume they dried out from not being used due to the fass he had on it). So all was well no fuel leak for about 2500 miles then I had a new leak it was coming from the lift pump so I put new banjo sealing washers on the fittings on it and it is still leaking but I can not tell where it is coming from it is wet underneath the lift pump and drips down from the starter. Anyone have any ideas? Is my lift pump going out? Thanks Aaron
