Measure from the outside of the tread on driver side to the outside of the tread on the passenger side on the front of your steer tires, that is measurement "X"Bump! and what do you mean by measure the toe???
Its not too bad, I did them by myself in about 4 hours. Just make sure you unbolt your track bar, and I also had to unbolt the upper control arm on the passenger side, and still use a bottle jack to get the axle far enough down to slide in the spacer.Is it a pain in the butt to install the spacers??? Thanks fellas:thumbsup
