I just ordered a 2.5" leveling kit from hell bent steel. Do i need to get the sway bar link extensions or longer shocks for this kit or can i just put them in and get it aligned?
On the Hell Bent website they say the sway bar drop brackets are required for lifts over two inches. i'm pretty sure your shock length should be fine though
I bought the extensions for a 2" lift and did not need. Couldn't even get them in. I do kind of wish I had changed shocks at the same time, while you got everything apart but I don't think is necessary.
Marc
Vendor
It depends on the year of the truck. The 2010+ trucks have slightly longer factory links so you can get away with them. The 03-09 trucks have shorter ones that will most likely get bent with a 2"+ lift and eventually break. It is suggested to replace the shocks at the same time.:thumbsup:
go to tropguncustomz.com and look around some,You can fi you much gure out how much you want to spend
