Leveling kit
1426 Views 11 Replies 8 Participants Last post by  newkid24
I would like to level my truck but don't want to spend a lot on a spring kit. Who is running a good spacer kit with no problems or any other upgrades needed?
1 - 12 of 12 Posts
I have the one from Hell Bent Steel. Easy installation and so far no problems.
i'm running a 2.5 no name i got for free, thinking its hell bent, slapped it in to do until my lift, no additional parts installed, no problems at all
Sounds good. I just want to level it for now until I buy a good kit.
Yeah if you're gonna be doing much driving off road before you get the better kit longer shocks would be a good idea since it doesn't take alot to limit them out after the leveling kit is installed
I also have the hell bent 2" no issues. An adjustable track bar would be a good idea but not totally necessary.
03 qcsb 2500 mild 48re 4x45.9 HO
edge jwa 50hp inj fass titanium 150
leveled on 35s
I think the Carli 2" spring is cheaper than a spacer. Unless I am mistaken. I remember thinking oops after I was done and saw that.
Not much off-road at all just don't like the factory stance. Did it change the ride quality much?
Did you guys get the swaybar drop kit with the hellbent spacers?
Just another option, on other trucks I've owned with a ton of stock rake, Ive done a spacer or a 2" lowering shackle or a combo of both. If it's a 2wd and you'd like some better aero or lower COG, a rear shackle can be a great option. I had a 4WD F150 with a 2" spacer that left the back still about 1" high. I used a shackle to get it about 1/2" lower than the front. Loved it
When it comes to coil spacers they are all the same. $50 spacer kit will work as well as a $200 spacer kit.
Longer shocks are need as well.
I bout my 2.5" on ebay for 50 bucks. passenger side was a pain using a bumper jack to get spring clearance but its in :) well spent money!
1 - 12 of 12 Posts
