1 - 3 of 3 Posts
I have a 2003 2500 4x4 and am planning on getting a leveling kit to run 35s on my stock rims in the spring. I have never lifted or leveled any of my trucks, how important is it to re-center the axle after doing the lift? What happens if you don't? Whats the best way to do it I'm a college student on a tight budget. Is their any kits that include everything, also I was interested in the Kore leveling kit but does this also require re-centering the axle?
If the axle isn't centered with stock wheels you may slightly rub the inner fender lining (plastic) that can easily be trimmed enough to negate the issue. A leveling kit and a set of control arms should set you up to not require anything else with zero rubbing. An adjustable track bar helps center everything up as well.
1 - 3 of 3 Posts
