1 - 4 of 4 Posts
hey guys,
I have read the posts about why you should and why you shouldn't install spacers on the truck.
I have a question about the truck itself.
Does installing the 2 inch spacer lift the front over the rear and make the truck look like the rear is sagging. I had a 3 inch pro comp lift kit in my old truck and I had to put blocks in the rear to lift it up to level the truck. 3 in the front and two inch in the rear.
can any of you guys share pics of your trucks from a side profile with or without the spacers?
:yourock:
Nice! I LOVE the fender flares!
If you do install the spacers, make sure you have (or get) an adjustable trac bar and a set of Maxx Links to correct the swaybar angle. Then once installed take the truck to a competent dealer or alignment shop.
1 - 4 of 4 Posts
