I have an 06 3500 quad cab short box that I currently have a 2"(I think) leveling kit, 35x12.50r17 toyo mts on 17x8.5" wheels with a +15 off set. I have a canopy and feel it barely has any rake to it empty and then loaded down it looks like its sagging, then add the car trailer and it definetly is low in the rear. I am looking at replacing the tires with toyo ATIIs in a 285/75r18 size as I think the 18" wheels will look better and they will be narrower and over 12 lbs lighter each tire which seems like a good option while keeping the same diameter.
Is there a 1" leveling kit out there? I have considered a rear 1" lift but think if I could lower the front an inch I would be doing the same thing cheaper and with better handling etc. then that leads me to think that maybe stepping down to a 285/75r17 would also be an option with less fender gap on the front if the flares didn't make them look too small.
Picture attached is my truck parked totally empty.
I have been running the current set up for 4-5 years and get ok mileage but an improvement would be nice if it doesn't look too goofy with the fender flares which I am stuck with. With the current online sales buying wheel/tire combo is cheaper than just the tires locally so good excuse to get some new wheels. The current +15 off set seems about as high as I would like but going with an almost 2" narrower tire leads me to think that I could get away with even maybe a 0mm offset but don't have any experience with these trucks to know.
Looking for options and/or opinions about which direction to go.
