1 - 12 of 12 Posts
How many people have used the 2" front leveling kit and then added 2" rear blocks also. I don't like the prerunner look and every picture I have seen with just the front leveling kit is leaning back.
This is the setup I like so far:
New KORE HP Leveling Kit - Dodge Ram Suspension
eBay Motors: SUSPENSION 2" LIFT BLOCK KIT_ DODGE RAM 2500 & 3500 4X4 (item 310041831222 end time Apr-23-08 04:24:15 PDT)
Any reason this wouldn't work well? I think I will also add the rear matching Bilstein shocks.
Part #: F4-BE5-C614-H0
SAP Part #: F4-BE5-C614-H0
Setting: Heavy Duty (HD)
Position: Rear
List Price: $ 121.00
Actually, the level kits usually keep the rear slightly higher than the front. Sounds like what you want is a 2" lift, not a level kit.
What you have listed will work.
Are the shocks included with the Kore kit longer than stock?
LOL, I would hope so or thats one crappy kit!
Nah, seriously, they should be, otherwise I dont know why they would include stock length shocks with the 2" taller springs...
Like Pauly said, most leveling kits I have seen still keep the back higher by a tad, and actually its mostly visual anyway.
I put a Top Gun Customz 2" (steel) leveling kit in the front and made my own 3/4" spacers for the rear. My truck sits just a little higher in the rear then the front.
I use Thuren's heavy duty rear shackles. They have 3 mounting positions for height adjustments, stock, one inch higher, and 2 inches higher. They allow you to fine tune the lift, are extremely stout and have a greasable bushing:thumbsup
Discussion Starter #8
This is what I'm talking about, just a front leveling kit, looks like a prerunner. The front is perfect height, I just want to bring the back up with it.
Discussion Starter #9 (Edited)
Good idea on the shackle, is it more expensive than the blocks? I think the blocks are about $89 bucks shipped.
Discussion Starter #10
I used this guys truck as an example, good looking truck, mine is the same color except Mega.
Vigilante
I put a 2 1/2" leveling kit on my 06 mega cab and mine does not sit higher in the front. You also will save a lot of money going with a leveling kit and rear blocks. Go with a 2 1/2" leveling kit and a 2" block for the back, and wala you have a 2" lift kit for roughly $180.00. Just remember that you have a 2 piece drive shaft on your mega cab so you will need to shim your carrier bearing. Very easy to do. If I remember right it is a 1/4" of shim for every 1" of block heighth. Somebody correct me if I am wrong on that. 2 1/2" leveling kit on ebay is like 90 bucks shipped and ebay also has a 2" rear block kit with u bolts for roughly 90 bucks. If you know a farmer they will surely have some scrap metal 1/4 to a 1/2 thick you could cut to make your own shims. As far as new shocks. you are raising your shocks so you SHOULD never bottom them out. As far as topping them out, well if thats the way you drive your truck than you'll have more than that to worry about. Just my point of view, but I have done this on quite a few trucks, NO PROBLEMS.:thumbsup
Vigilante
I just looked at you original post closer. That is the exact block kit I was talking about in my last reply. Just go to the main page of ebay and search for, dodge leveling kit, and there you are. Good luck.:thumbsup
1 - 12 of 12 Posts
