Well I'm pretty sure my HG is leaking coolant at the very back of the motor. It doesn't seem to be a very bad leak and my radiator is usually always close to full, only takes maybe a cup or two of coolant to fill it every few thousand miles so more of a seepage than a leak I guess.
Is it possible that its just seeping out under higher boost? My boost only hits 28psi max on my hx35 with the wastegate blocked off at WOT so I'm not running any kind of crazy boost numbers.
And finally what would you do if you were in my position? Would you just leave it and keep driving and not worry about it? Retorque the head and see if it fixes anything? New Hg? Truck just hit 230k, I also have a pic of the back of the motor and that's about 5k miles worth of buildup.
