My truck is leaking a lot. It is leaking motor oil. The leak is coming from the drivers side of the truck. I can't quite see where it is coming from but it is somewhere above the oil pan. It is a 1999 Dodge Cummins 24 valve. I remember reading somewhere that it was a common problem for the vacuum pump to leak and I am beginning to think that may be my problem. also, When I have the brakes on, the truck is almost impossible to steer if it isn't moving. I was just thinking this might be part of the problem.
Is there any way to beter diagnose from wear the leak is coming from? It has to start at 1 spot but it is trickling down everywhere and I can't fintd a trail to trace it.
Thanks for any help,
John
John
